0 Replies Latest reply on Aug 18, 2014 3:54 PM by Avishai Dov
    non uniform pressure
    Avishai Dov
      hello,
      I built a program that take a part and apply pressure on some faces.attached with the part (if you are trying to run it so put all the files in "F:\" folder, Or change the letter in the code).
      I need to change the code that I will can apply non-uniform pressure.
      there is a hint how to do it in the help of API but i cant understand how to do this:2012 SolidWorks API Help - ICWPressure Interface Members
      the part of the code i need to change in order to apply non-uniform pressure( know it's apply a regular pressure):
          Set CWPressure = LBCMgr.AddPressure(0, (varArray2), Nothing, errCode)
          If errCode <> 0 Then ErrorMsg SwApp, "No normal pressure created.", True
          Call CWPressure.PressureBeginEdit
          CWPressure.Unit = 0
          CWPressure.value = 0.1
          errCode = CWPressure.PressureEndEdit
          If errCode <> 0 Then ErrorMsg SwApp, "Nonuniform pressure distribution not set.", True
      please help me, it's very important.
      thank you.
      Avishai
