1 Reply Latest reply on Aug 18, 2014 6:47 PM by Jamil Snead
    How to dimension 180 degrees?
    Nathan Cassou
      I am having trouble making a 180 degree dimension on a line because the Smart Dimension wants to dimension the length. Any thoughts?
        • Re: How to dimension 180 degrees?
          Jamil Snead
          Are you trying to set the 180 degree angle between two lines? If so you need to start them out at some other angle so they aren't parallel, then add the angle dimension and change it to 180 degrees. Usually a parallel relation would accomplish the same thing, but if you are using a design table to change this angle in different configurations then that would be one reason to use an angle dimension instead of parallel relation.
