Macro to do Slddrw to PNG without background?
Question asked by Flemming Nielsen on Aug 18, 2014
Latest reply on Sep 15, 2014 by Daniel Andersson
Hi All,
I need a macro to export a PNG picture of a drawing, without background and preferably in a specific DPI.
I found a macro made by Deepak Gupta here https://forum.solidworks.com/message/385536?sr=search&searchId=9c5b419d-93e7-41af-9c5a-923a03005185&searchIndex=0#385536
where I managed to get it saving a PNG, but still with a white background.
The code is;
Dim swApp                     As SldWorks.SldWorks
Dim swModel                   As SldWorks.ModelDoc2
Dim swSheet                   As SldWorks.Sheet
Dim vSheetNameArr, vSheetName As Variant
Dim bRet                      As Boolean
Dim lErrors                   As Long
Dim lWarnings                 As Long
Dim fileName                  As String
Dim strOriginallyActiveSheet  As String
Set swModel = swApp.ActiveDoc
' Is document active?
If swModel Is Nothing Then
    swApp.SendMsgToUser2 "A Drawing document must be active.", swMbWarning, swMbOk
    Exit Sub
' Is it a Drawing document?
If swModel.GetType <> swDocDRAWING Then
    Exit Sub
If swModel.GetTitle = "" Then
    swApp.SendMsgToUser2 "Save the Drawing first", swMbWarning, swMbOk
    Exit Sub
fileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
fileName = Left(fileName, InStrRev(fileName, ".") - 1)
'Change/Set DPI Settings and Paper Size here
swApp.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swTiffPrintDPI, 300
swApp.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swTiffPrintPaperSize, swDwgPaperSizes_e.swDwgPaperA4size
Set swSheet = swModel.GetCurrentSheet
strOriginallyActiveSheet = swSheet.GetName
vSheetNameArr = swModel.GetSheetNames
For Each vSheetName In vSheetNameArr
bRet = swModel.ActivateSheet(vSheetName): Debug.Assert bRet
swModel.ViewZoomtofit2
swModel.Extension.SaveAs fileName + ".PNG", swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, lErrors, lWarnings
Next vSheetName
swModel.ActivateSheet (strOriginallyActiveSheet)
