I was wondering if someone could guide me in the right
direction. I am creating a sloped aluminum drain pan and I
started it bycreating an extrusion from a sketch. I then
created a shellby removing the top 2 faces. When I go to
convert theextrusion to a sheet metal part, I receive a failure
notice sayingno bends were found and could not flatten all bends.
As far aswhich corners to rip, I selected all 4 corners plus the
edge/cornerat each end of the small flat section on the bottom.
I've attached an image of the file since I don't know how to attachthe file itself.
Thanks in advance for any help!!!!
To attach the file, you must first add it to a zip file.
SA
