0 Replies Latest reply on Aug 16, 2014 1:06 AM by Yong Ning
    How to get memory in open SldDrw or SldAsm
    Yong Ning
      Follow code can be open SldDrw file
      Help me, while open SldDrw or SldAsm, how to get memory value .
      Function Timing(T)
         Dim Ss, h, m
         Ss = Timer - T
         h = Int(Ss / 3600)
         m = Int((Ss Mod 3600) / 60)
         Ss = Int(Ss Mod 60)
         Debug.Print h & ":" & m & ":" & Ss & ""
         MsgBox h & ":" & m & ":" & Ss & ""
      End Function
      ''返回装配体中所有零件和子装配体的实体名。
      Function SwOpenFile(SwApp, OpenFile)
         'Debug.Print OpenFile
      '    SwApp.Visible = True
         Dim SwModel As Object
         Dim nDocType As Long
         Dim nErrors As Long
         Dim nWarnings As Long
         Dim swOpenDocOptions_Silent
         swOpenDocOptions_Silent = 1
         ' Determine type of SolidWorks file based on file extension
         If InStr(LCase(OpenFile), "sldprt") > 0 Then
             nDocType = 1 'swDocPART
         ElseIf InStr(LCase(OpenFile), "sldasm") > 0 Then
             nDocType = 2 'swDocASSEMBLY
         ElseIf InStr(LCase(OpenFile), "slddrw") > 0 Then
             nDocType = 3 'swDocDRAWING
         Else
             ' Probably not a SolidWorks file...
             nDocType = swDocNONE
             '...so the file cannot be opened
             Exit Function
         Set SwModel = SwApp.OpenDoc6(OpenFile, nDocType, _
      swOpenDocOptions_Silent, "", nErrors, nWarnings)
         'SwApp.Visible = True
         Set SwOpenFile = SwModel
         'Debug.Print SwModel.GetPathName
      End Function
      Private Sub test()
      Dim T: T = Timer
      Dim SwApp As SldWorks.SldWorks
         Set SwApp = GetObject(, "SldWorks.Application")
      Dim OpenFile
         OpenFile = Cells(2, 1)
      SwOpenFile SwApp, OpenFile
      Timing T
