I am trying to model this with a sweep but i cant workout how to create the sketch to extrude it? i must be missing something simple?
Can you attach your *.sldprt attempt here?
What version of SWx?
I would use a projected curve intersection of 2 2D sketches as the sweep path.
Perhaps I'm missing the obvious, but if "cutting a cylinder then shelling it" created what you needed, why are you wanting to re-create it as a sweep?
Yeah, I posted the image in case you had an older version. Hopefully the image shows enough information for you to re-create the part.
here is one in SW13, I went a different way than Kelvin, he got me thinking, I know there is an easier way, them bam! it hit me
I used 2 extrudes, deselected the merge results, makes 2 bodies, then used the combine tool to fined the common volume of the parts, then shelled for the wall thickness.
I always forget the common thing with the combine tool very powerful modeling with multiple bodies!!!
yes I know the tube isn't square, but hay you have to do something
Then start with a different profile "tube".
