Hello all,
Got a bit of an irritating problem where there are a lot of parts in assemblies that have been set to transparent for various reason but now it's no longer needed. Is there a way to select all the parts in a top level assembly and turn the transparency off?
Cheers,
Matthew
That depends where the transparency was set and whether Display States are involved.
If it was set at the assy level, you should be able to right-click in the Feature Manager Display Pane, and select Clear all top level overrides.
If Dipslay States are involved, you may be able to simply delete the offending Display State.
