Hello all,
Ive recently noticed that if sweep profile sketch (surface or solid) contains sketch fillets and offset; and also using keep normal constant option, resulting sweep has one all around face instead of selectable separate faces according to sketch entities. see image.
is there help? ive seen old SR-s about it but in 2014 version i have same issue. I have few workarounds but is there a straightforward solution?
Thank you for help,
Mile
I think the reason is that when you keep normal constant the profile shape normal to the path is changing, so a cross section would show that the arcs are no longer circular, but become oval. Since they aren't arcs anymore I think that's why SW doesn't separate the faces.
But if you absolutely need the face divisions you can sweep each segment as a surface sweep (still keep normal constant) and then knit all the surface together.
