3 Replies Latest reply on Oct 24, 2014 11:12 AM by Jerry Wolverton
    How can I select a radio button on data card with api, preferrably in vb.net
    Jerry Wolverton
      I have three radio buttons on my data card linked to the same variable.  I can manually select the different radio buttons to change the variable value, but I would like to add that control to an api I am writing for my addin.  Is there a way to control which radio button is selected through api's?
      Jerry
        • Re: How can I select a radio button on data card with api, preferrably in vb.net
          Ar K
          For selecting :
          radiobutton1.checked=true
          for control:
          if radiobutton1.checked=true Then
          elseif radiobutton2.checked=true Then
          radiobutton3.checked=true Then
          End if
          Or
          For Each obj As Object In Me.Controls
                  If obj.Name.Contain("radio") Then
                        if obj.checked=true Then
                        End if
          Next
              Jerry Wolverton
              Thanks for the reply, Ar K
              Sorry for the late reply.  I got bumped off this project but am not back on it.  I have since been able to detect the radio button, but I cannot find a way to activate it.
              It looks like I should have been clearer in my question.  Looks like you are referring to a custom made windows form, but what I meant by "data card" was the EPDM data card.  So I do not know what the radio button's call name is upfront because I did not create the card with code, but rather used the EPDM card creator and dragged and dropped the radio buttons in.
              That all being said, I have been able to find the radio button of interest on the data card, but can't find a way to activate it.  My code to find it is:
              swFile = v.GetFileFromPath(swPathName, swFolder)
              dataCard = swFolder.GetCard("slddrw")
              ctrlPos = dataCard.GetFirstControlPosition
              While Not ctrlPos.IsNull
              dataCardCtrl = dataCard.GetNextControl(ctrlPos)
                   ctrlType = dataCardCtrl.ControlType
                   If ctrlType = EdmCardControlType.EdmCtrl_RadioColumn Then
                        If dataCardCtrl.Name = "Part" Then
                             str = ""
                             str = "Card Control: " & dataCardCtrl.Name
                             str = str & vbLf + "Control ID:" & dataCardCtrl.ID
                             str = str & vbLf + "Variable ID:" & dataCardCtrl.VariableID
                             str = str & vbLf + "Control Type:" & ctrlType
                             MsgBox(str)
                             '*** found the radio button, but do not know how to activate it!!!***
              End While
              Jerry Wolverton
              Just to put closure to this question, I decided to skip over the step of trying to call to the Data Card to preform a task, and jump right to the variables that the task would have impacted and changed them directly.  So, I changed my method of solving the problem and therefore do not need to manipulate the Data Card radio buttons.
