Hi Everybody,
I have been trying to put an edge flange all around large slot ( for LED light ) but no luck.
Its should be 10 mm long flange ( R 3 ) going inwards and it will be pressed with special tool
which means that this cut out on flat pattern should be smaller than you see right now.
Would you be able to share your ideas how to model this flange?
Thank you so much.....
Edge-Flange17 didn't like the Bend Deduction used. Switching to a K-Factor resolved that problem.
Also, deselecting the Simplify Bends option in the Flat-Pattern(1) resolved a graphics problem which occurred with Boss-Extrude5 when flattened.
