I am trying to get my head around Revisions in EPDM.
To clarify my understanding can anyone tell me if my following understanding is right/wrong.
Local Revisions
- There is an internal Revision scheme within EPDM, which I am calling Local Revisions as that is what is displayed in my task pane.
- This revision scheme is automatically incremented via the Inc. Revision command in a transition
- This variable cannot be mapped to a data card
- It can be used for files that do not have a data card, eg PDF, work docs, non-SW files etc
- Do I need to use this Rev scheme, can I just use my SW Revision variable (see below)
SW Revision
- This is a revision scheme I have created based on the variable Revision that I have set up within EPDM and use throughout my SW files.
- This variable can be mapped to a data card
- This variable can be incremented via the Set Variable-next revision command
- This variable is not changed via the Inc. Revision command in a transition
- Used for SW files only
Is there anyway to map the SW Revision to the Local Revision
For example:
- I have a file I want to push through my workflow
- The file already has the SW Revision Variable set to B but the Local revision is blank
- When pushed into a state called concept, I want both the Local Revision and the SW revision to be B
I have found a way to do this using a mass of transitions and states to define each possible rev and using multiple Inc. Revision commands, but this seems messy.
Jason
Jason,
I'm not exactly sure if you completely understand EPDM Revisions. Please forgive me if I tread familiar water.
In EPDM, a Revision is a version that is flagged as a Revision. This helps a user understand that this is a version to pay particular attention to. If a user does not have permission to see working versions then he will only see the versions flagged as a Revision. Also, a version marked as a Revision will never be placed in cold storage. Revision schemes are set up by the administrator and are triggered to increment, usually to the next one, in a workflow transition. Additionally, users can be given permission to increment a Revision manually. You can have a variable in EPDM that is set to the current or next Revision by adding this action in the transition. This is what we do. We also map the EPDM variable to the SolidWorks property so they will be the same. Hope this helps.
