If I make numerous changes at the sub-assembly level the changes will only be "seen" by the SolidWorks viewer unless I update and re-enter the top level assembly into the Vault.
Of course, in normal SolidWorks, if you open a top-level assy all of the sub-assy updates will be loaded and thus viewable - even though the top-level assembly hasn't been explicitly updated in the Vault.
In a workgroup environment, when you have numerous people working on their own specific sub-assembly and making updates, it is simply unmanageable to reload and re-update the top level in order to register these changes to the outside world. For example, our manufacturing group relies on the SolidWorks viewer to view engineering designs.
Is there a workaround? Is this problem solved with Enterprise PDM?
You could still work the way you are asking. Check out the assy to a common area and proceed to make the changes. You can wait until the assy has been updated before checking it back in.
