0 Replies Latest reply on Aug 12, 2014 6:08 PM by jason van clark
    AutoDimension2 not working correctly editing sketch in context
    jason van clark
      I have a sketch that I am editing in context.  I am trying to place dimensions on the sketch automatically.  I first create two lines, one vertical, one horizontal, based on the origin.  I then use those lines as my horizontal and vertical datums for the autodimension2 function.  It will not work!  It keeps dimensioning to the edges of the part.  What am I doing wrong!?
              Sub addDims(ByVal swSketch As Sketch, ByVal swModel As ModelDoc2)
                  Dim sketchPoints As Object
                  Dim nretval As Integer
                  Dim bool As Boolean
                  Dim sketchmgr As SketchManager
                  Dim tempMod As ModelDoc2
                  tempMod = EditedPart.GetModelDoc2
                  'Dim LocalOrigin As Entity
                  'LocalOrigin = EditedPart.GetCorresponding(origin)
                  sketchmgr = swModel.SketchManager  'get the sketch manager
                  sketchPoints = swSketch.GetSketchPoints2  'get the sketch points in the sketch
                  swModel.ClearSelection2(True)
                  tempMod.ClearSelection2(True)
                  If originPoint IsNot Nothing Then
                      Dim HorizLine As SketchSegment
                      Dim vertLine As SketchSegment
                      HorizLine = sketchmgr.CreateLine(0.0#, 0.0#, 0.0#, 0.021598, 0.0#, 0.0#)
                      sketchmgr.CreateConstructionGeometry()
                      vertLine = sketchmgr.CreateLine(0.0#, 0.0#, 0.0#, 0.0#, 0.025063, 0.0#)
                      bool = vertLine.Select3(True, swAutodimMark_e.swAutodimMarkHorizontalDatum, Nothing)
                      bool = HorizLine.Select3(True, swAutodimMark_e.swAutodimMarkVerticalDatum, Nothing)
                  Else
                      bool = origin.Select3(True, swAutodimMark_e.swAutodimMarkHorizontalDatum, Nothing)
                  'bool = swModel.Extension.SelectByID2("Point1@Origin", "EXTSKETCHPOINT", 0, 0, 0, False, 8, Nothing, 0)
                  'bool = LocalOrigin.Select2(False, 0)
                  If bool Then
                      nretval = swSketch.AutoDimension2(swAutodimEntities_e.swAutodimEntitiesAll, _
                  swAutodimScheme_e.swAutodimSchemeOrdinate, _
                  swAutodimHorizontalPlacement_e.swAutodimHorizontalPlacementBelow, _
                  swAutodimVerticalPlacement_e.swAutodimVerticalPlacementLeft)
      this is what I get:
      Jason
