I have a rectangular pan that has a hole in the center. The hole is lower than the edges. I am trying to use a swept boss to create a solidbe tween the edges of the pan and the center hole. I have a cross section I am trying to swept but no luck.
Is the swept boss the best when to do this?
You might need to use a loft feature. If you need the entire part to be uniform thickness then consider modeling either the inside or the outside of the entire part with surfaces first, then use the thicken command.
