Hi All
So for some time now I have just let this problem go but now it's just annoying me.
Does anyone know how to show a electrical routing components properties in a normal BOM list in an assembly 2D drawing view.
Now what I can gather a electrical routing component or Wire is made of two things, the Assembly and the Part.
The BOM in an assembly view shows the Assembly level of the Electrical component.
I can manually input the cable data for things such as material and inventory numbers but the part number remains as a hyphen ( - ) in the cell on the BOM.
I do not want to create a separate drawing just for the one cable/wire data.
This their a correct way to import the cable/wire info into a normal BOM or do I have to do it all manually and omit the Part number information and enter it manually into that cell?
Below is an example:
The Cable/Wire is Item 20. As you can see at first placement of the BOM no information is entered into the BOM and the Part number is Simply a hyphen.
If anyone can help with this simply annoying problem. I would be a happy man again.
Kindest regards
Stephen Brett
