I have a strange issue on a bucket shell, using split I removed the required material on both sides, and when I flatten the shell - the sides are straight instead of radius sides. Was trying to search and fix the issue, but so far I did not find what exactly is wrong. Also weird is the way SolidWorks is flatten the part holding the top instead holding the bottom.
Does anybody know what's wrong?
Thanks!
I'm using 2013 and the flat has curved edges.
what is the split for? are you just trying to trim?
if you edit the flat pattern feature you can change the fixed face.
if you don't really need the split you can redefine the planes and extrude to them instead of trying to cut.
I used a sketch to define the planes
