Issue with BOM Macro
Question asked by Trevor Wunn on Aug 11, 2014
Latest reply on Aug 12, 2014 by Trevor Wunn
Good Afternoon Everyone,
I'm having an issue with my code that I could use some advice on. The macro is supposed to run on a drawing, load the model if it isn't already, find a BOM, if it finds one, select it, find items in the bom and combine them.
It is getting stuck right after it selects it. I know I'm missing something but I'm not sure what it is.
Thanks for your help!
-Trevor
Option Explicit
Dim swTable As SldWorks.TableAnnotation
Dim swBomTable As SldWorks.BomTableAnnotation
Dim swBomFeat As SldWorks.BomFeature
Dim swFeat As SldWorks.Feature
Dim swView As SldWorks.View
Dim swAnn As SldWorks.Annotation
Dim swSelData As SldWorks.SelectData
Dim numCol As Long
Dim numRow As Long
Dim i As Long
Dim j As Long
Dim boolStatus As Boolean
Dim pipeTotal As String
Dim pipeLength As String
Dim pipeQuantity As String
Dim flatBarTotal As String
Dim flatBarLength As String
Dim flatBarQuantity As String
Dim longStatus As Long
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
'Load model
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
boolStatus = swView.LoadModel()
'If boolStatus = True Then
'    MsgBox "Model Loaded. Please insert new" & Chr(34) & "Top-Level Only" & Chr(34) & "BOM and select it before proceeding", vbCritical, "Error, Son!!"
'    Exit Sub
'End If
'Rename first BOM found
Set swFeat = swModel.FirstFeature
Do While Not swFeat Is Nothing
    If "BomFeat" = swFeat.GetTypeName Then
        boolStatus = True
        swFeat.Name = "Bill of Materials1"
        swFeat.Select (False)
    If (boolStatus) Then Exit Do
    Set swFeat = swFeat.GetNextFeature
Loop
'Select BOM
While Not swView Is Nothing
    Set swAnn = swView.GetFirstAnnotation3
        While Not swAnn Is Nothing
            Debug.Print swAnn.GetName
            If swTableAnnotation = swAnn.GetType Then
                boolStatus = swAnn.Select3(True, swSelData)
            Set swAnn = swAnn.GetNext3
        Wend
Wend
XXXXXXXXXXXX This is where I am having issues XXXXXXXXXXX
Set swTable = swSelMgr.GetSelectedObject5(1)
Set swBomTable = swTable
Set swTable = swBomTable
Set swBomFeat = swBomTable.BomFeature
pipeTotal = 0
pipeLength = 0
pipeQuantity = 0
flatBarTotal = 0
flatBarLength = 0
flatBarQuantity = 0
numCol = swTable.ColumnCount
numRow = swTable.RowCount
For i = 0 To numRow - 1
    For j = 0 To numCol - 1
        If swTable.Text(i, j) = "STL PIPE 1.25, SCH 40" Then
            pipeLength = swTable.Text(i, j + 1)
            pipeQuantity = swTable.Text(i, j + 3)
            pipeTotal = pipeTotal + (pipeLength * pipeQuantity)
            Debug.Print "Current Pipe Quantity: " & pipeTotal
        ElseIf swTable.Text(i, j) = "STL FLAT BAR .25 X 5" Then
            flatBarLength = swTable.Text(i, j + 1)
            flatBarQuantity = swTable.Text(i, j + 3)
            flatBarTotal = flatBarTotal + (flatBarLength * flatBarQuantity)
            Debug.Print "Current FlatBar Quantity: " & flatBarTotal
    Next j
Next i
pipeTotal = (Int((((pipeTotal * 1.1) / 12) / 21)) + 1) * 12 * 21
Debug.Print "Final Pipe Total: " & pipeTotal
flatBarTotal = (Int((((flatBarTotal * 1.1) / 12) / 20)) + 1) * 12 * 20
Debug.Print "Final FlatBar Total: " & flatBarTotal
swBomFeat.PartConfigurationGrouping = swDisplay_ConfigurationWithSameName_AsOneItem
For i = 1 To numRow
If swTable.Text(i, 2) = "STL PIPE 1.25, SCH 40" Then
    swTable.Text(i, 3) = pipeTotal
    swTable.Text(i, 4) = "-"
    swTable.Text(i, 5) = "1"
    swTable.Text(i, 6) = "FIELD FIT"
ElseIf swTable.Text(i, 2) = "STL FLAT BAR .25 X 5" Then
    swTable.Text(i, 3) = flatBarTotal
Next
