1 Reply Latest reply on Aug 10, 2014 4:56 AM by Deepak Gupta
    Part is not rebuilding
    Sanya Shmidt
      Hello guys!
      Can someone look at this simple code below an tell me what am I missing. It changes the dimension, but it is not rebuilding the part. (But message says Rebuild process took place.)
      I have to manually hit rebuild button to rebuild the part.
      Dim swApp As Object
      Dim boolstatus As Boolean
      Set swmodel = swApp.ActiveDoc
      swmodel.Parameter("WL@Sketch1").SystemValue = WL * 0.0254
      If swmodel.EditRebuild3() Then
              MsgBox "Rebuild successful"
          Else
              MsgBox "This model has rebuild errors"
      Video is here
      https://dl.dropboxusercontent.com/u/23443066/Rebuild.wmv
        • Re: Part is not rebuilding
          Deepak Gupta
          Try:
          Sub Main()
          Dim swApp       As SldWorks.SldWorks
          Dim swModel     As SldWorks.ModelDoc2
          Dim bRet        As Boolean
          Set swModel = swApp.ActiveDoc
          swModel.Parameter("WL@Sketch1").SystemValue = WL * 0.0254
          bRet = swModel.EditRebuild3
          If bRet Then
              Else
