I have a multi-configuration part to which I am adding sketch text. The text needs to change depending on the configuration. I have the custom properties linked to a design table and need to pull the proper text from there. When I attempt to link the text to a custom property that references the design table, Solidworks crashes. I can link the text to other custom properties (that don't reference the design table) without a problem. I have attempted every different way to do this with the same results: rebooting, redoing sketch, linking sketch to properties then linking properties to design table, vice versa... Is this a known problem and is there a workaround?
