I am using an SAE J1926-1 ORB Fluid Power Port on the face of a circular housing. I am able to import the ORB into a part file but apparently I cannot in an assembly? Why is this and is there a way around this problem by allowing me to insert the ORB directly into the assembly? If there isn't a solution, I guess I can waste time by drawing the port into the assembly, but I'd rather not have to.
Andrew
