I have a long pipe with 2 pressure gauge in it, static pressure gauge/
When I measured pressure in real (examination test in my laboratory) I got pressure of 1.46 bar and 1.27 bar
When I tried to simulated that in flow simulation my input boundary condition was of 1.46 bar static pressure as inlet pressure but as you can see in the
picture the pressure in the other gauge is 1.41 bar not 1.27 bar as in real test i did
What could be the problem?
Oshri
Possibly you need to add surface roughness to the pipe and this would reduce the pressure.
Check to see that your gages are calibrated. Look at both your test setup and the simulation setup for refinement. Cheers, Mark
