If a virtual wall is added to a Simulation study, then suppressed after solving, the error "database not found" appears when trying to change between plots. Has anyone had this error, and is there a workaround? I don't see reference to the problem in the knowledge base.
why suppress the virtual wall in the study after solving?
at that point the results don't match the setup
database not found happens when the results are disconnected from the study, and I don't know if I expect it to happen from suppressing an element, but at the same time, your workflow isn't standard either
if this happens in any file any study, I would report to your var
workaround would be to not suppress the virtual since it seems strange to do it in the first place
