I have been trying to run a simulation study on a structure for a project; the structure will be used to support a pan mold from a center pivot column but need to have very minimal deflection or sag. I need to verify material sizes to ensure my design meets our criteria; however I am having issues when trying to run the study for this structure. It is a combination of structural members (i-beams and tubing) as well as standard extrustions (mounting plate). The structure is to be bolted to a bearing that will be attached to the center pivot column and I have been trying to apply a load of 700lbs to the flat portion of the model but am having issues with it not terminating or blowing up? Any help?
where are you stuck?
handling the bearing? have you checked the bearing examples?
mixed meshing? have you checked the mixed mesh tutorials?
my suggestion, start simple, usually where your restraint is and with a gravity load and slowly add components. if something doesn't work, at least you;'ll know what you added to cause the issue so it is easy to troubleshoot
