I am doing some testing before we upgrade from EPDM 2012 to 2014 and noticed that when I Check In a file it is not saving locally first, therefore it is not Checking In my changes? Is this a setting? I thought default behavior for Check In was to Save Local then Check In. If I Save first then Check In everything works but this is an extra click.
Thanks, Todd
UPDATE: I only get this behavior if I do NOT Check Out the file before making a modification to the file. On EPDM 2012 I could modify the file first without having it Checked Out, then Check Out and Check In and file would get saved locally. With EPDM 2012 I am forced to Check Out before making any modifications if I want my modifications to get Checked In.
Hi Todd, I believe this is intended behaviour.
If you open a file without checking it out and then save, you are creating a new file effectively.
To keep your modified changes and create a new version of the same file, you will need to check out, make changes, save locally, then Check in.
Kind regards,
Prasad
