Afternoon all,
I am making some Molex connectors assemblys with pins and connectors as the parts. I want to put these into my electrical design library so I can drag and drop to start my routes. When I place the Cpoints in the pin PARTS and then assemble them into the connector assembly, by dragging and dropping these, route will not start. I can only put the Cpoint at the ASM level of the connector and THEN when I drag and drop the connector asm route starts up. Only thing is, those asm Cpoints, all of the stub properties are grayed out and I cannot set my stub up. I can only set up the stub if I do a Cpoint in the prt level. But then SW will not start the route command automatically by dragging and DROPPING.
Need some help please.
sid
