Greetings All
I hope I am in the right area..... I am having difficulty dropping an ISO fluid power port (from the design library). It seems that I need a concentric edge to locate the ISO port. Do I have to make a circular cut feature first and then drop the ISO port onto the face and then select the concentric edge of the cut feature, or is there a better way around this.
Regards
Regards
If the part you're putting the port into is square/rectangular, you'll want to use the corresponding port type. Once you've placed the port onto the face and chosen your size, you'll see a box in the FM asking for locating edges. Select two edges and it's there.
If your part is round, see above, but you'll only need to select one edge.
