2 Replies Latest reply on Aug 4, 2014 11:30 AM by Andrew Wilford
    Trying to select renamed Front Plane
    Andrew Wilford
      I am trying to select the Front Plane, which has been renamed in the part template file.
      I have enumerated the part features and found the three plane features. I have tried using GetSpecificFeature2 to convert the IFeature to an IRefPlane and doing a straight cast
      IRefPlane* refPlane = (IRefPlane*)feature;
      I then try to use IGetRefPlaneParams and get_Transform to get the plane normal to see if it is the Front Plane. The code keeps crashing and the examples don't help. There are so few useful C++ examples.
      Does anyone know how to achieve this in unmanaged C++?
        • Re: Trying to select renamed Front Plane
          Artem Taturevych
          You need to call ->QueryInterface (not direct cast) from the IDispatch returned from GetSpecificFeature2 to get the valid pointer to IRefPlane*.
          1 person found this helpful
            Andrew Wilford
            Thank you, that worked. Here is a code snippet, in case anyone needs to do something similar:
              IDispatch* dispatch = NULL;
              IRefPlane* refPlane = NULL;
              feature->GetSpecificFeature2(&dispatch);
              HRESULT hr = dispatch->QueryInterface(__uuidof(IRefPlane), reinterpret_cast<void**>(&refPlane));
              if(refPlane != NULL) {
                  double *data = new double[16];
                  refPlane->IGetRefPlaneParams(data);
                  if(fabs(data[6]) < 1e-6 && fabs(data[7]) < 1e-6 && fabs(data[8] - 1.0) < 1e-6) {
