How to define a mixture of water and gas in the flow simulation,i am giving an input of air at one end of the pipe.
And there is an other inlet through which water will be entered into the pipe.
I want to find out the outlet temperature at other end of the pipe.
Can the tracer study module be used for finding the temperature at the other end?
Please do share your suggestions.
Thanks and Regards,
M.Gopala krishna murthy.
Do the air and water mix inside? If the volume of each changes (if any point inside the tube changes from being full of air to full of water) Flow will not solve for that change. It can mix gases with gases or liquids with liquids, but it does not re-mesh to handle change of matter.
