Does anyone know why this is? I edited the errors in the file but then could not save it to the folder due to a read only folder. I saved it to another place and then moved it to the correct SWdata file folder (below). It still did not work Then I updated the software to SP4 (while the file I saved was in the location of the ai file) and it worked only it now works with the file I entered as a base file and won't accept the old file back in as a base file. I've tried to re-install the service pack with the old file in its original folder, I've tried to re-name the file that I saved as the file name that it is supposd to be, along with a number of other things, but none of them seem to work. SW is still looking for the file that I fixed and saved as another name in the index () Now when I do anything to change the file back and try to insert a SHSS nothing happens. I can chose the hole and then click the add button but nothing happens.
I HATE trying to explain issues in a forum. It seems they are never understood and I can't explain them in terms that others understand and answers take on wierd tangent lives of their own. Has anyone had this problem, tried to fix it, and ended up in an even worse situation like I am in now? I suppose I could just leave the file I renamed and call it good but I'm afraid that it will rear its ugly head as some other unforseen problem down the road.
You might have similar issue as here: https://forum.solidworks.com/message/440911#440911
If you've not done any kind of customization to toolbox, I would recommend to reinstall it. Also do report this to your VAR.
