5 Replies Latest reply on Jun 29, 2018 8:20 AM by Anthony Macke
    Drawings stuck in 'Draft Quality' and unknown feature tree icon...
    Lee Gregory
      Dear all,
      I know this may have been resolved before, but I am yet to find a conclusive answer on these forums.
      I have a drawing with a medium sized assembly (6100 parts) in. I have 7 views in total including 3 CS views.
      All of these views seem to be stuck in Draft Quality with no option to turn it off. The "View > Display > Draft Quality HLR/HLV" is greyed out, therfore I am unable to change this. My page is set to high quality in Page Setup.
      When I print I get the standard "Next time you open, views will be high quality etc..." However, when I re-open the drawing, this remains the same.
      I also have this 'egg timer' on my drawing views in my feature tree. I don't know what this means either. SEE ATTACHED JPEGEggTimer.JPG
      I am well and truly stuck and have no more options but to ask you guys.
      CAN ANYONE HELP ME GET THESE DRAWING VIEWS BACK TO HIGH QUALITY?
      I am running SW2009.
      ANY HELP IS GREATLY APPRECIATED. THANKS IN ADVANCE.
        • Re: Drawings stuck in 'Draft Quality' and unknown feature tree icon...
          Deepak Gupta
          Make a copy of the drawing and then open the copy to see if that helps.
          Suppress a lot of components in the assembly to make the assembly lighter and then open the drawing. You might see some error but click OK and see if that helps. Do make sure to keep a copy of assembly and other files before trying.
            Andy Sanders
            The egg timer means SW is crunching away at updating the views.  That's probably why you can't change anything yet until the egg timer goes away.
            Do they ever go away?  Can you leave it be for 5-10 min just to see what happens?
            You may want to look at "lightening" the geometry, as Deepak said.  That should cut down on the crunching SW has to do to generate the views.
              pablo gutierrez
              dude, try to load up your drawings in lightweight mode or large assembly mode.
              you can also change the settings in the system options so you can update the views manually..
                Elmar Klammer
                Just an updated to this problem that might resolve the issue. If you have imported parts inside your assembly that have faults then the drawing will permanently be stuck in draft quality. Look for all imported parts and run a check (tools -> check) to see if there are any faults listed. Note: that SW does not indicate if  an imported part has errors. It seems that running import diagnostics and resolving issues is needed if you require drawings to resolve fully down stream. Another option to try is under System options where you can check "ignore self-intersection check for some sheet metal features" under the "performance" section.
                Maybe it helps someone. Below is the vba code from solidworks api site somewhat altered. It will highlight the error faces and select them and print a numbered list to the immediate window so you can do all this semi automated. A good start anyways.
                Thanks to hawkridge & sw support for this info....
                ' Preconditions: Part or assembly is open.
                ' Postconditions: None
                Option Explicit
                Function GetStringFromID(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, vPIDarr As Variant) As String
                    Dim vPID                        As Variant
                    For Each vPID In vPIDarr
                        Debug.Assert vbByte = VarType(vPID)
                        GetStringFromID = GetStringFromID & Format(vPID, "###000")
                    Next vPID
                End Function
                Sub ProcessFaultEntity _
                ( _
                swApp As SldWorks.SldWorks, _
                swModel As SldWorks.ModelDoc2, _
                swEdge As SldWorks.Edge, _
                swFaultEnt As SldWorks.FaultEntity _
                    Dim swModExt                As SldWorks.ModelDocExtension
                    Dim vPIDarr                 As Variant
                    Dim nCount                  As Long
                    Dim swEnt                   As SldWorks.Entity
                    Dim bRet                    As Boolean
                    Dim i                       As Long
                    nCount = swFaultEnt.count: If 0 = nCount Then Exit Sub
                    Set swModExt = swModel.Extension
                    vPIDarr = swModExt.GetPersistReference3(swEdge): Debug.Assert Not IsEmpty(vPIDarr)
                    'Debug.Print "    Edge ID = " & GetStringFromID(swApp, swModel, vPIDarr)
                    For i = 0 To nCount - 1
                        Set swEnt = swFaultEnt.Entity(i)
                        If Not swEnt Is Nothing Then
                            bRet = swEnt.Select4(True, Nothing): Debug.Assert bRet
                        Debug.Print "      Fault[" & i & "]                         = " & swFaultEnt.ErrorCode(i)
                    Next i
                    Dim swApp                   As SldWorks.SldWorks
                    Dim swModel                 As SldWorks.ModelDoc2
                    Dim swPart                  As SldWorks.PartDoc
                    Dim vBodyArr                As Variant
                    Dim vBody                   As Variant
                    Dim swBody                  As SldWorks.Body2
                    Dim nRetval1                As Long
                    Dim nRetval2                As Long
                    Dim vEdgeArr                As Variant
                    Dim vEdge                   As Variant
                    Dim swEdge                  As SldWorks.Edge
                    Dim swFaultEnt              As SldWorks.FaultEntity
                    Dim i                      As Long
                    Dim bRet                    As Boolean
                    Set swModel = swApp.ActiveDoc
                    Set swPart = swModel
                    Dim ii As Integer
                    Debug.Print "File = " & swModel.GetPathName
                    vBodyArr = swPart.GetBodies2(swAllBodies, True): Debug.Assert Not IsEmpty(vBodyArr)
                    ii = 1
                    For Each vBody In vBodyArr
                        Set swBody = vBody
                       ' Debug.Print "  Body[" & swBody.GetType & "] --> " & swBody.GetSelectionId
                        nRetval1 = swBody.Check ' obsolete method
                        nRetval2 = swBody.Check2 ' obsolete method
                             If nRetval2 <> 0 Then
                        Debug.Print ii & "  " & " Body[" & swBody.GetType & "] --> " & swBody.GetSelectionId
                        Debug.Print " Body2::Check (1 if valid; 0 if not)   = " & nRetval1
                        Debug.Print " Body2::Check2(number of faults)       = " & nRetval2
                        swBody.Select True, -1
                        ii = ii + 1
                        vEdgeArr = swBody.GetEdges
                        On Error Resume Next
                        For Each vEdge In vEdgeArr
                            Set swEdge = vEdge
                            Set swFaultEnt = swEdge.Check
                            ProcessFaultEntity swApp, swModel, swEdge, swFaultEnt
                        Next vEdge
                    Next vBody
