I'm having some issues trying to do a tricky bend. I'm trying to create a part that represents a piece of vinyl which has been bent/deformed around a few edges. The important thing here is that I need to be able to generate a flat pattern so that the future parts can be cut from that.
I've attached a photo showing how the vinyl is being bent, the trouble area is the angled section that is bent back with a triangle shape and then meets the wall. If I try to do each bend separately using sheet metal tools it ends up with messy cuts and a gap etc.
Does anyone have any suggestions that may be able to help?
If you flatten the part you have made you will see that the material overlaps itself. There needs to be a triangular gap in order to make it from one continuous flat piece of material.
In general, to reduce gaps you can change the default Auto Relief in the Sheet Metal feature to tear. Also what I frequently do is flatten the part, then extrude material in to fill in the gaps, and then fold it again. If you are editing the flat part, you need to make sure that the bend boundaries never cross each other. Also if the part has tears sometimes it won't let you cut or extrude material to the unfolded part because it gets confused when it tries to merge. This can be prevented by changing the flange positions to Bend Outside.
This is the best I could do with your part:
And here is the part flattened. You can see there is no room to add more material.
Unfortunately I have SW2014 so you wouldn't be able to open my part if I attached it. But hopefully you can duplicate the same procedures.
