I have flow going through a chamber against a rotating drum fitted with pins (see image.) The flow leaves the chamber through the large round surface at the bottom.
A rotating reference frame would not be appropriate for this application, since the flow will definitely not be axisymmetric around the drum. Is there a way to implement a rotating boundary condition on the drum? What is the best solution?
Probably not a good for for flow. Talk to your var who will pass your query to the developers.
Moving wall would not work most likely.
