Whenever I open a part, I get the above mentioned error. I was on SW2014 SP0.0, I updated to 4.0 to try and remedy the error, and it didnt fix it. Does anyone know what causes this error/how to get rid of it?
Tyler
Tyler
That was happening on my new Windows 8.1 computer with SW 2014 SP 4.0, and we just had to enable .NET 3.5 (which includes 2.0 and 3.0 it says) under "Turn Windows Features on or off" in Programs and Features...Then after some downloading and installing from Windows Update, we're good to go. No more error. I hope that helps others with the SolidWorks error: "Could not load SolidWorks DLL: GdtAnalysisSupport.dll."
Hello Tyler ,
With Reference to Solidworks KB , I have attached This solution. Kindly try this out to fix this issue .
If your upgrade or install was performed after July 15th, 2015 the most likely explanation is a known conflict caused by Microsoft® update KB 3072630 which was released on July 15th, 2015. This update makes changes to the Windows Installer.
To address this problem, try the following steps with your IT department’s assistance if required:
Standalone installs:
1. Click 'Start', click 'Run', type "regedit" in the 'Open' box, and then click 'OK'.
2. Locate and click the following subkey in the registry: HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Installer
Note: If this subkey does not exist, create it.
3. In the 'Edi't menu, point to 'New', and then click 'DWORD Value'.
4. For the DWORD name, type "RemappedElevatedProxiesPolicy", and then press 'Enter'.
5. Right-click "RemappedElevatedProxiesPolicy", and then click 'Modify'.
6. In the 'Value' data box, type 1, and then click 'OK'.
7. Run a Repair of your SOLIDWORKS Installation (S-050527)
8. After the application installs successfully, reset the 'RemappedElevatedProxiesPolicy' DWORD value to "0" to re-enable the security fix for KB 3072630.
Administrative Image installs:
1. Uninstall SOLIDWORKS from Programs and Features
2. Click 'Start', click 'Run', type "regedit" in the 'Open' box, and then click 'OK'.
3. Locate and click the following subkey in the registry: HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Installer
4. In the 'Edit' menu, point to 'New', and then click 'DWORD Value'.
5. For the DWORD name, type "RemappedElevatedProxiesPolicy", and then press 'Enter'.
6. Right-click "RemappedElevatedProxiesPolicy", and then click 'Modify'.
7. In the Value data box, type "1", and then click 'OK'.
8. Install SOLIDWORKS from your Administrative Image
9. After the application installs successfully, reset the RemappedElevatedProxiesPolicy DWORD value to "0" to re-enable the security fix for KB 3072630.
Reference of this post is S-069491. I hope these steps will slove your issues.
Regards,
N.Vignesh
Hi Tyler ,
Hope by registering the Exe you can fix this issue . Follow the steps Below :
1) Go to windows ‘Start’ > type cmd
2) RMB on ‘cmd.exe’ > select ‘Run as administrator’
3) In windows explorer Navigate to <SW installation folder>, (where sldworks.exe is contained)
4) Drag and drop ‘sldworks.exe’ in command prompt and type
/regserver
Typically the command would look like
"C:\Program Files\SOLIDWORKS Corp 2013\SOLIDWORKS\sldworks.exe" /regserver
5) Press ‘Enter’ > this will register ‘sldworks.exe’
6) Reconfirm behavior.
Regards ,
N.Vignesh
On my SW12 was the same problem, and this advise easy and totally solve The problem. VIGNESH NAGARAJAN Thanks!!!
/regserver
"C:\Program Files\SOLIDWORKS Corp \SOLIDWORKS\sldworks.exe" /regserver
Regards ,
N.Vignesh
Shot in the dark here: see if you have TolAnalyst selected in Options->Addins. If so, deselect it.
