9 Replies Latest reply on Jul 1, 2016 7:50 AM by Yong Ning
    How to active configuration in bom of part
    Yong Ning
      Can traverse configuration, but cannot activate the  configuration of (a1,a2,a3,a4)
      https://forum.solidworks.com/servlet/JiveServlet/downloadImage/2-440382-148735/450-312/1.jpg
      Private Sub ll1()
        Dim SwModel As ModelDoc2
          Set SwModel = Application.SldWorks.ActiveDoc
        Dim Params As Variant, SwConf As Configuration
          Params = SwModel.GetConfigurationNames
          For ii = 0 To UBound(Params)
             Set SwConf = SwModel.GetConfigurationByName(Params(ii))
             With SwConf
                Debug.Print .Name,
                Debug.Print .BOMPartNoSource,
                Debug.Print .AlternateName,
                .AlternateName = ii
                Debug.Print .Comment,
                .Comment = .Name
                Debug.Print .Type
                ss = .GetParameters(aa, .Name)
             End With
          Next ii
      In this code
      Can traverse Configuration , result is
      a2             8            0             a2             0
      a3             8            1             a3             0
      a4             8            2             a4             0
      a1             8            3             a1             0
      Help me
        How to active configuration.
        active configurate a1,a2,a3,a4
        • Re: How to active configuration in bom of part
          Artem Taturevych
          IBomTableAnnotation::BomFeature->BomFeature::Configuration
              Yong Ning
              Why  follow code don't active configuration?
              question
                     .Configuration = "a3" →
                     Debug.Print .Configuration → result "a1"
              Private Sub main()
                Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
                  Set SwApp = Application.SldWorks
                  Set SwModel = SwApp.ActiveDoc
                Dim SwSelMgr As SelectionMgr
                  Set SwSelMgr = SwModel.SelectionManager
                Dim SwBomFeat As BomFeature
                  Set SwBomFeat = SwSelMgr.GetSelectedObject5(1)
                  Debug.Print SwBomFeat.GetFeature.Name
                Dim Visible(3), ss(3)
                  ss(0) = "a1"
                  ss(1) = "a2"
                  ss(2) = "a3"
                  ss(3) = "a4"
                  Visible(0) = False
                  Visible(1) = True
                  Visible(2) = False
                  Visible(3) = False
                  SwBomFeat.SetConfigurations False, Visible, ss
                  Stop
              Private Sub main()
                Dim SwSelMgr As SelectionMgr, Visible
                  SwModel.ShowConfiguration2 "a3"
                  With SwBomFeat
                     .SetConfigurations True, Visible, "a3"
                  End With
                  Yong Ning
                  'This example shows how to get the custom properties for the configurations in a document.
                  Option Explicit
                  Public Enum swCustomInfoType_e
                      swCustomInfoUnknown = 0
                      swCustomInfoText = 30       '  VT_LPSTR
                      swCustomInfoDate = 64       '  VT_FILETIME
                      swCustomInfoNumber = 3      '  VT_I4
                      swCustomInfoYesOrNo = 11    '  VT_BOOL
                  End Enum
                      Dim swApp                   As SldWorks.SldWorks
                      Dim swModel                 As SldWorks.ModelDoc2
                      Dim swConfig                As SldWorks.Configuration
                      Dim vConfName               As Variant
                      Dim vPropName               As Variant
                      Dim vPropValue              As Variant
                      Dim vPropType               As Variant
                      Dim nNumProp                As Long
                      Dim i                       As Long
                      Dim j                       As Long
                      Dim bRet                    As Boolean
                      Set swModel = swApp.ActiveDoc
                      Debug.Print "File = " + swModel.GetPathName
                      vConfName = swModel.GetConfigurationNames
                      For i = 0 To UBound(vConfName)
                          Set swConfig = swModel.GetConfigurationByName(vConfName(i))
                          nNumProp = swConfig.GetCustomProperties(vPropName, vPropValue, vPropType)
                          Debug.Print "  Config       = " & vConfName(i)
                          For j = 0 To nNumProp - 1
                              Debug.Print "    " & vPropName(j) & " <" & vPropType(j) & "> = " & vPropValue(j)
                          Next j
                          Debug.Print "  ---------------------------"
                      Next i
                  Private Sub ll1()
                         With SwConf
                            SwModel.ShowConfiguration2 .Name
                            SwModel.ViewZoomtofit
                          End With
                      Next ii
                      Artem Taturevych
                      This works for me in 2014:
                      Private Sub main()
                          SwBomFeat.Configuration = "a2"
                          Yong Ning
                          thanks your tips
                          This works for me in sw2011.
                          question
                              Debug.Print SwBomFeat.Configuration → result is "a1" → Hope result is "a2"
                          Hope "a1" change "a2"
                          SolidWorks Forums: Partnumber-configuation Macro
                          https://forum.solidworks.com/message/440898#440898
                          In this tips, my question is
                          Set Configuration BOM Property to Configuration Name.swp
                          How to  set Configuration Bill Of Materials options to Configuration Name?
                          key code →
                                  Set sConfig = swModel.GetConfigurationByName(sConfigName) →  sConfig name
                                  what mean for BOMPartNoSource?
                                  sConfig.BOMPartNoSource = swBOMPartNumber_ConfigurationName
                            Yong Ning
                            Find the reason, your code can only run in drawing, don't run in part.
                                SwBomFeat.Configuration = "a3"
                                Debug.Print SwBomFeat.Configuration → result is a3.
                            Private Sub main()
                                Artem Taturevych
                                It runs successfully in parts as well for me in 2014.
                                    Yong Ning
                                    Why follow code runs successfully in parts as well for me in SW2014
                                    Private Sub Main3()
                                        Dim SwConf As Configuration
                                           Set SwConf = SwModel.GetActiveConfiguration
                                           SwBomFeat.Configuration = SwConf.Name
                                           SwModel.ForceRebuild3 True
                                           Debug.Print SwBomFeat.Configuration, SwConf.Name
                                        'Stop
                                    but in Sw2013, the code don't runs successfully in parts.
                                      key  code
                                    result SwBomFeat.Configuration → "a1" , Hope SwBomFeat.Configuration  → "a3"
                                  Yong Ning
                                  Private Sub TraverChangeBOMconfiguration()
                                      Dim Str, tmp
                                         Str = "Bill of Materials1"
                                      Dim ConfArr, swConf As Configuration
                                         ConfArr = SwModel.GetConfigurationNames
                                         For ii = 1 To UBound(ConfArr)
                                             tmp = SwModel.Extension.SelectByID2("Bill of Materials1", "BOMFEATURE", 0, 0, 0, False, 0, Nothing, 0)
                                             SwModel.ShowConfiguration2 ConfArr(ii)
                                             Set swConf = SwModel.GetActiveConfiguration
                                             SwBomFeat.Configuration = swConf.Name
                                             SwModel.ForceRebuild3 False
                                             Debug.Print SwBomFeat.Configuration, swConf.Name, SwBomFeat.GetFeature.Name
                                             'Stop
                                         Next ii
                                      'Stop
                                  Private Sub Main3()
                                      Dim swConf As Configuration
                                      'Stop
