0 Replies Latest reply on Jul 21, 2014 8:33 AM by Unspecified Unspecified
    Display of the angular sizes
      Incorrect display at the indication of the admission on the angular size.
      Task: it is required to set the size 30 ° ±30’. Not 30 ° ±0,5 °, and 30 ° ±30’.
      If to set the admission having written down ±30’ in the Size Text window, the sign "plus/minus" differs from a similar sign if to specify the admission in the Admission/accuracy window.
      It is impossible to set seconds in the Admission/accuracy window, at least if to change units of measure to degrees/min. in the Replace Units of Measure window, it is impossible to remove excess accuracy. Record turns out following: 30 °0 '±0 °30’.
