0 Replies Latest reply on Jul 21, 2014 3:34 AM by Giorgio Petroni
    FillPatternFeatureData SkippedItemArray
    Giorgio Petroni
      Dear all,
      I have a problem with a fill pattern on SW2014. I need to dynamically skip some items. I see that this is possible with the property SkippedItemArray on the FillPatternFeatureData object. My problem is that I don't understand how the row id and column id are generated.
      Here is how fill pattern is generated:
      The skipped items (4,2) in the image above is the top left item of the image below
      If I run my code and I try to skip item 3,1 (zero - based) it works. The problem starts when I change the sheet metal dimensions because I'm not able to predict the row id and column of this item.
      Thank you
