It is a neat feature that when dimensioning between a line and a construction line you can specify the distance as if the construction line was a center line. Is there a way to do this if both lines are construction lines (double distance)?
I drew a circle and changed it to dashed line display. It is to show the overall diameter of the bolt circle pattern, and Solidworks will not let me "Smart Dimension" it.
dimension to the endpoint of the non-center construction line.
