Hello, I am currently remaking a solid design from a already cut out design of a base for a new machine. The design needs to be remade with a few extra parts but majority of it is a redesign because the person who had the software for the design lost it. So, I basically have to remake it from the machine. I am almost done except I ran across a error that cannot be solved because of the zero thickness geometry error. I am new to solidworks and overall cad design and can't make a cut that is needed.
Another problem that occured is when I actually try to make the extruded cut it makes a double shape of the actual shape I need. I assume it is because of how I designed the shape (with lines and points) but I can't figure out how to fix that either.
This is the shape with the selection of the shape highlighted.
This is the problem with the cut having two L shapes when it should only be one. I actually want to make a cut with those two lines being the point to start and spot and even making a cut on the circle between them.
Here is another angle of the shape:
Any tips on how to make the cut would be amazing. I know it is possible because the shape was created using solidworks and 3D printing, I apparently haven't taught myself enough solidworks to know how to fix it yet.
Thanks.
Firstly, you have the Thin Feature option selected. That is why you are seeing 2 thin feature cuts.
To have only 1 cut, make the cut profile closed. i.e. convert & trim the edges where the horizontal & vertical sketch lines terminate.
