I want to create a 3d sketch to trim certain part of the object I have. So I created points on the 3d surface and then connected the points using 3d spline on surface. However when i use this sketch to use as a trim entity, it gives me an error (see image attached). I am not sure why it says that the 3d sketch doesnot intersect. Any insights on this or work arounds for this situation? How can I check if my 3d sketch is coincident on the surface or not?
Part available here.
Nisha,
Using your 3d spline create a extruded surface and use that surface as your cut surface.
since it is a 3d spline you will have to specify the direction of the extrude.
Frank
