hello everyone,
many times I want to export some features colors to a DXF file, from the 3D model. for example, for the following part, I want the DXF to look like that (the numbers in yellow, the color of the feature.)
this is what I do. I do an extruded cut, define its color to yellow. then I export the face or flat pattern, open in Draftsight, for example and change the color to yellow once again.
Is there a way to automate this process?
Thank you.
DXF doesn't have that capability from the solid, sorry.
But if you make a SW drawing and change the colors there, then save as a dxf the colors will follow.
