0 Replies Latest reply on Jul 15, 2014 5:15 AM by Yong Ning
    How to update the result of a sketchText statement?
    Yong Ning
      use follow code, don't update result.
      The need to open the sketch feature with manually, and then double-click the sketchtext,
      to obtain the sketchtext  required result.
      For example, the original text is HG20592, into HG20592-2009.
      Must double-click(open) the sketch in feature tree, and then double-click the HG20592, can be changed to HG20592-2009
          SwModel.ForceRebuild3 False→ don't refresh sketchtext → text
      Private Sub ll2()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
        Dim SwSelMgr As SelectionMgr, SwFeat As Feature
          Set SwApp = GetObject(, "SldWorks.Application")
          Set SwModel = SwApp.ActiveDoc
          Set SwSelMgr = SwModel.SelectionManager
          Set SwFeat = SwModel.FeatureByName("草图1")
        Dim SwSketch As Sketch
          Set SwSketch = SwFeat.GetSpecificFeature2
        Dim vSkSegArr
          vSkSegArr = SwSketch.GetSketchSegments
        Dim SwSkText As SketchText, TxtForm As TextFormat
          For ii = 0 To UBound(vSkSegArr)
            Select Case vSkSegArr(ii).GetType
                  Case swSketchLINE
                      Set swSkLine = vSkSegArr(ii)
                  Case swSketchARC
                      Set swSkArc = vSkSegArr(ii)
                  Case swSketchELLIPSE
                      Set swSkEllipse = vSkSegArr(ii)
                  Case swSketchSPLINE
                      Set swSkSpline = vSkSegArr(ii)
                  Case swSketchTEXT
                      Set SwSkText = vSkSegArr(ii)
                      With SwSkText
                         Set TxtForm = .GetTextFormat
                         .Text = "HG20592-2009 法兰BL200-25 RF 质量10.2kg 兰州宁先生编制"
                      End With
                      With TxtForm
                         .WidthFactor = 0.5
                      End With
                      SwSkText.SetTextFormat False, TxtForm
                  Case swSketchPARABOLA
                      Set swSkParabola = vSkSegArr(ii)
                  Case Default
                      Debug.Assert False
              End Select
          Next ii
