I've perfomed a non linear simulation of a valve seal compression.
These are the results.
Before compression:
after compression:
Suppose there's a fluid leak on the right side, as shown in this picture:
This is what will happen:
- fluid will enter the seat
- it will apply pressure to the seat and the rubber seal
- seal will deform and change its shape
- more zones of the seal (anche the seat) will be subject to pressure
- pressure will deform the seal
- new seal shape will determine new pressure distribution
Is there any way to simulate this with non linear analisys ?
the big problem here is that you don't know in advance what regions/faces of the seal will be pushed by fluid pressure and also seal deformation changes faces/regions that are subject to fluid pressure.
Thanks.
Alex
Unfortunately, I don't think you'll be able to directly simulate this. All I can think of (realistically) is looking at the contact pressure between the o-ring and the valve and making sure that it is higher than the fluid pressure.
You could estimate the size of the area that the fluid pressure is acting over (per the results you've posted) and use that to divide up the o-ring's geometry such that you can apply a pressure load over the new sub-region. This pressure load's pseudo time function will need to be defined such that it comes into play after the o-ring has been compressed. Of course, this won't capture that additional area of the o-ring that will be exposed to the fluid pressure (which will then result in more o-ring deflection).
To account for this, you could do one of two things:
Of these two ways, item #2 is the most realistic (#1 would be very time consuming, but I think it's technically possible).
