3 Replies Latest reply on Jul 15, 2014 10:14 PM by Artem Taturevych
    Add number of 3d points on sketch segment at equal interval;
    Sushil Chaskar
        Is there any way by which I can add a number of 3d points on sketch segment of 3dsketch using api ?
        • Re: Add number of 3d points on sketch segment at equal interval;
          Sean Phillips
          SolidWorks API Help
          GetTessPts Method (ICurve)
          Gets a set of points that represent the tessellation of this curve.
          Function GetTessPts( _
             ByVal ChordTolerance As System.Double, _
             ByVal LengthTolerance As System.Double, _
             ByVal StartPoint As System.Object, _
             ByVal EndPoint As System.Object _
          ) As System.Object
          Parameters
          ChordTolerance
          Chord tolerance to use in tessellation (meters); this is the maximum permitted distance from a cord to the curve between the cord endpoints; the smallest allowable value for this parameter is 1E-8; if 0.0 or a value smaller than 1E-8 is specified, then 1E-8 is used by default
          LengthTolerance
          Length tolerance to be used to filter out very short segments (meters); this method does not return tessellated segments shorter than this value
          StartPoint
          Array containing the start point of the curve
          EndPoint
          Array containing the end point of the curve
          Return Value
          Array of doubles containing the tessellation points (see Remarks)
          Remarks
          The array returned contains the x, y, z location of the tessellation points:
          [ x1, y1, z1, x2, y2, z2, ... ]
