1 Reply Latest reply on Jul 15, 2014 3:57 AM by Deepak Gupta
    Drawing Title Block - adding created by and date for the model, and drawn by and date
    Sanya Shmidt
      Hello guys,
      Can someone tell me what would be the easiest way to fill out automatically the following fields on the title block?
      CREATED BY     DATE
      DRAWN BY     DATE
      In our company engineers create parts, and drafters do the drawings on a different machines.
      May be there is an easier way of doing that. What I have so far is a Macro that reads windows user login name and creates a property Author. It is automatically detecting if model is open or the drawing.
      I guess for the DRAWN DATE I can use $PRP:"SW-Short Date" in the sheet format. But what about the CREATED DATE (when the model was created)?
      ' Alex Shmidt (C)2014
      ' For PSI/PPPI
      ' Define variable used to hold the SldWorks object
      Dim swApp As Object
      Dim wshNet As Object
      Dim sMatName As String
      Dim sMatDB As String
      Dim TopName As String
      Dim retval As String
      Set swModel = swApp.ActiveDoc
      Set wshNet = CreateObject("WScript.Network")
      ' Constant enumerators
      Const swDocPART = 1
      Const swDocASSEMBLY = 2
      Const swDocDRAWING = 3
      If swModel Is Nothing Then
          ' If no model is currently loaded, then exit
          Exit Sub
      ' Determine the document type.
      Select Case swModel.GetType
          Case swDocPART
              Set swPart = swModel
              sMatName = swPart.GetMaterialPropertyName2("Default", sMatDB)
              If sMatName = "" Then
                  swApp.SendMsgToUser ("Material is uknown. Please specify material.")
              swModel.CustomInfo("Material") = sMatName
              ' creating new property if doesn`t exist
              If swModel.CustomInfo2("", "Author") = "" Then
                  retval = swModel.AddCustomInfo3("", "Author", swCustomInfoText, "=")
              ' get part creator user name
              swModel.CustomInfo("Author") = UCase(Left(wshNet.UserName, 2))
          Case swDocASSEMBLY
              ' do nothing for now
          Case swDocDRAWING
              If swModel.CustomInfo2("", "DrawnBy") = "" Then
                  retval = swModel.AddCustomInfo3("", "DrawnBy", swCustomInfoText, "=")
              'get user name for drawing DRAWN BY
              swModel.CustomInfo("DrawnBy") = UCase(Left(wshNet.UserName, 2))
      End Select
          Set wshNet = Nothing
          Set swApp = Nothing
      Any help is appreciated.
