1 Reply Latest reply on Jul 13, 2014 11:25 PM by Artem Taturevych
    Generate cross sections in increments and save the file with increment number
    Rashiga Walallawita
      Hi All,
      I've a task where I need to generate cross sections in increment lengths in a comples shape. I need to save the dawring of that cross section which the  file name should be the cross section distance i've taken from a referance point.
      Here the things i've done so far,
      1. I created the cross section using extruded cut profile where small section is left out so to get a cross section.
      2. thought about how the macro should work
      Strat loop
      > select the extrude cut sketch
      > edit the dimension form the referance point in a increment
      > switch to the dawring view
      > save the already set front elevation ,with the file name "length from the referance point".dwg
      > continue the loop from begining till the nu,ber of steps reach a certain value.
      3. I tried to record a macro and edit it, but since i'm new to solidworks api I coudlnt code it correctly. Here's the code,
      For i = 0 To 5
      Set Part = swApp.ActiveDoc
      boolstatus = Part.Extension.SelectByID2("Sketch1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
      Part.EditSketch
      Part.ClearSelection2 True
      boolstatus = Part.Extension.SelectByID2("D2@Sketch1@vajja.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
      Dim myDimension As Object
      Set myDimension = Part.Parameter("D2@Sketch1")
      step = i / 10
      myDimension.SystemValue = 1 + step
      Part.SketchManager.InsertSketch True
      swApp.ActivateDoc2 "vajja - Sheet1", False, longstatus
      longstatus = Part.SaveAs3("F:\2014\sw_ergo\vajja.SLDDRW", 0, 2)
      Next i
      I get the error in the following red colored line.
      Some help would be highly appreciated.
      Thanks in Advance.
      Regards!
