Customize Menu Bar flyout with Add-in [VB]
Question asked by Daniel Andersson on Jul 13, 2014
Latest reply on Jul 16, 2014 by Daniel Andersson
Hello!
I have tried and tried and can not figure out how to do this... I'm able to create regular menus as image below shows (Ready for TC) etc.
But when it comes to modify the flyout on the menu bar I get stuck. I have googled and search this forum with no luck. I hope that someone here can guide me...
What I want to do is to add a button to the area marked with the read box. I'm using visual studio VB express 2010. Running SolidWorks 2012 sp5.
I have created the add-in with the templates provided from the SDK that came with SolidWorks 2012 sp5.
I belive that this would be possible using the command manager... but I do not figure our how. Cross my fingers to get help here
As reference here is the current code in the AddCommandManager() for the add-in. It is almost out of the box from the SW add-in templates.
    Public Sub AddCommandMgr()
        Dim cmdGroup As ICommandGroup
        If iBmp Is Nothing Then
            iBmp = New BitmapHandler()
        Dim thisAssembly As Assembly
        Dim cmdIndex0 As Integer, cmdIndex1 As Integer
        Dim Title As String = "Ready for TC"
        Dim ToolTip As String = "Ready for TC"
        Dim docTypes() As Integer = {swDocumentTypes_e.swDocASSEMBLY, _
                                       swDocumentTypes_e.swDocDRAWING, _
                                       swDocumentTypes_e.swDocPART}
        thisAssembly = System.Reflection.Assembly.GetAssembly(Me.GetType())
        Dim cmdGroupErr As Integer = 0
        Dim ignorePrevious As Boolean = False
        Dim registryIDs As Object = Nothing
        Dim getDataResult As Boolean = iCmdMgr.GetGroupDataFromRegistry(mainCmdGroupID, registryIDs)
        Dim knownIDs As Integer() = New Integer(1) {mainItemID1, mainItemID2}
        If getDataResult Then
            If Not CompareIDs(registryIDs, knownIDs) Then 'if the IDs don't match, reset the commandGroup
                ignorePrevious = True
        cmdGroup = iCmdMgr.CreateCommandGroup2(mainCmdGroupID, Title, ToolTip, "", -1, ignorePrevious, cmdGroupErr)
        If cmdGroup Is Nothing Or thisAssembly Is Nothing Then
            Throw New NullReferenceException()
        Dim menuToolbarOption As Integer = swCommandItemType_e.swMenuItem Or swCommandItemType_e.swToolbarItem
        cmdIndex0 = cmdGroup.AddCommandItem2("Ready for TC", -1, "Get SW files ready for TC", "Adds, updates attributes and equations for Teamcenter", 0, "MsgTest0", "", mainItemID1, menuToolbarOption)
        cmdGroup.HasMenu = True
        cmdGroup.Activate()
        thisAssembly = Nothing
