Vary Sketch Not Changing Variable Instance Count
Question asked by Thomas Horst on Jul 11, 2014
Latest reply on Oct 22, 2016 by Rob Edwards
I'm having some problems with the "vary sketch" option when patterning, specifically when patterning other patterns.
If I actually change the dimension in the pattern seed sketch, the instance cound of the pattern varies correctly. But when patterned with "vary sketch", the patterned instances just contain the seed elements, not what the new version of the sketch would indicate that they ought to. I tried making a sketch patttern, and using a seperate linear pattern, and both behave the same. (file attached)
Has anyone else run into this, or know a workaround? Is it a bug, or intended functionality? I use V2012 SP4. so it is possible that it has been fixed in later versions.
Any input/suggestions appriciated.
TIA
-Thomas
