I am building a template for use by designers and need to control up to 21 holes on part. I used the assembly feature "cut-extrude"to create the holes and "propagated" them to the part however, the hole suppression/unsuppression at the assembly level does not control the part level. I can control the placement and the size of the holes...but not which ones to turn on/off at part level. This can almost make this feature un-usable if the designer has to go to the part and turn off/on the needed holes. They might as well draw them at that point. Any help would be appreciated.
If you want to control features at the part level, I would make the features at the part level. Maybe use assembly level sketches as templates?
