Hello all! I am running 2014 and have a simulation that I would like to probe the values for a linear cross-section through defined by the section plane and one face of the part. Is this still possible? I remember doing so in 2013 but it seems now I can only select individual points on the section plane and not a line or intersection of it with another face. Is it possible to probe whole section areas or borders of the same anymore? Thanks so much!
EDIT: It seems like 2014 has lost its interpolation capability, since even when I set it up as a Workflow sensitive sensor of points defined by me, it only gives me node values.
List selected on edges and faces only work on model faces and edges
So if you want to look at something specific, you need to split the model up first so they are selectable.
Otherwise in a section, you can prove and then export as sensors. But these are manual picks.
