9 Replies Latest reply on Apr 25, 2017 4:10 AM by Marcos Scheeren
    Help with SaveAs in macro
    Daniel Driscoll
      I'm having some trouple getting parts to save as an edrawing format. I've stepped through the program, everything is set to the expected values for all statements, but for some reason the SaveAs function returns false, no errors or warnings, and does not create anything in the target directory. If I use the supposedly obsolete SaveAs3 method (this is how it shows up when recording a macro), it even pops up the edrawings export configuration selection, but does not create a file.
      Public Function ExportNamedEdraw(swCompModel, ExportPath, sDocNameNoExtension) As Boolean
       Dim nErrors As Long
       Dim nWarnings As Long
          NewFilePath = ExportPath & sDocNameNoExtension
          If swCompModel.GetType = swDocPART Then
              NewFilePath = NewFilePath & ".EPRT"
          ElseIf swCompModel.GetType = swDocASSEMBLY Then
              NewFilePath = NewFilePath & ".EASM"
          bThrowaway = swApp.SetUserPreferenceIntegerValue(swEdrawingsSaveAsSelectionOption, swEdrawingSaveAll)
          ExportNamedEdraw = swCompModel.Extension.SaveAs(NewFilePath, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, nErrors, nWarnings)
      End Function
      Anyone have any ideas as to how to resolve this?
        • Re: Help with SaveAs in macro
          Sean Phillips
          This macro worked for me. I am not sure why you are having issues.
          Dim swApp As Object
          Dim modeldoc As ModelDoc2
          Set modeldoc = swApp.ActiveDoc
          ExportNamedEdraw modeldoc, "d:\", "myfile"
          Public Function ExportNamedEdraw(swCompModel As ModelDoc2, ExportPath, sDocNameNoExtension) As Boolean
          Dim nErrors As Long
          End Function
            Deepak Gupta
            It would be easy to debug if you can post the complete macro/codes.
                Daniel Driscoll
                The full macro is a bit of a mess, but I've gotten Sean's code to run successfully, so it must be related to something else in the code. I've attached the macro below so that you can take a look at it.
                I just tried some more debugging, and I think I've narrowed it down to the following issue:
                When passing a part to this function, I send a variable of type: ModelDoc2/PartDoc but in the function, it shows as a variable of type: Variant/Object/PartDoc
                The error then returns as 512 (swFileSaveAsNoSelection)
                I've updated the declaration to say As ModelDoc2 variable and it populates correctly with the ModelDoc2/PartDoc object as far as I can tell), but this doesn't seem to make a difference.
                The error still returns as 512 (swFileSaveAsNoSelection)
                      Daniel Driscoll
                      This is still throwing an error, but now it is a different error - 256, invalid file extension. I'm not sure how that could be, as the file extensions are correct, as far as I can tell. Does this script work for you?
                      Edit: There was one variable that had been mislabeled, Set ModelDocExt = swModel.Extension should be Set ModelDocExt = swCompModel.Extension
                      This still does not resolve the issue, however, now it gives error 1 - generic save error.
                      Also, changing to that obsolete SaveAs3 method does not work, returning the same generic save error (and if I remove the options, the edrawings configuration selection even shows up, but does not save)
                      I've also just tried this on a coworkers computer with the same failure.
                          Deepak Gupta
                          Works fine for me.
                          If I can know, what is the primary purpose of this macro for you? Only edrawings OR DWG/DXF also. I mean all the option given on the userform or just some of them. I'm asking this because then I can try to simplify the macro.
                              Daniel Driscoll
                              This macro really probably should be a plugin of some sort, I imagine, with all that is going into it, but it is basically a batch process for our sheet metal assemblies. Where I work, we generate a lot of sheet metal assemblies, and the DXFs and eDrawings are used in our shop for reference. Exporting all of these individually is tedious and error prone, so I've been working on this intermittently.
                              Daniel Driscoll
                              I tried changing the extension from .EPRT to .SLDPRT, and it saved the solidworks files. It also works when saving things as .igs files. I don't know how this helps me solve my problem (since I need eDrawings formats...), but maybe it is useful information.
